Mech
2018 IBC
Existing Mall Building
Sprinklered
I am assuming the construction type is either 2B or 3B.
Tenant Fitout plans from 1995 identify a 2 hour rated tenant separation wall as 6" metal stud with (2) layers of 5/8" fire rated gyp on each side. That is fine.
The new mercantile tenant's corporate architectural drawings call for plywood over top of the entire existing fire rated wall. I believe the intent is to use it as a substrate to attach shelving, displays, mirrors, etc.
Is this allowed? Must I find a rated assembly that allows plywood? Does the plywood need to be fire rated treated wood?
Can the plywood be left exposed? I assume if plywood is allowed, it can be covered with another sheet of gyp.
Sprinklered
