This is something we deal with fairly regularly.
Existing house, basement remodel, the owner wants to remove a bearing wall and replace it with an LVL beam. He gets the beam properly sized, and then he wants to hold one side of the LVL up with a column made of 2 2x4s, or some other effective means. His new column will now be bearing on the regular 4" basement slab, with no footing, that was not originally intended to carry whatever load is on the LVL as a point load.
Clearly, there is a certain amount of weight that the 4" slab can handle, but we don't know if it is really 4" thick, if it is reinforced, or what surface it was poured on.
So, I want to know how other jurisdictions handle this situation? How do you determine if they really need to cut the floor and add a footing, or if they can get away with a small point load on a regular slab?
Best case scenario, I would like to figure out a rule of thumb, like if the point load is only 1,000 lbs. we don't worry about it punching through the slab, more than 1,000 lbs. and they need to put in a footing. Of course, in the real world, it probably isn't that easy...
