beach
Gold Member
I have a pool in a condo project that, for security reasons, the association wants to put self-latching locks, keyed both sides, on their self-closing gates. Basically, you would not be able to egress the pool area without a key. I can't find any clear cut answer in the code (Calif.).... I know the "Latch" must be min. 5' above grade with a self closing gate opening out. Egress requirements in the code typically refer to exiting out of a building, but what if you are already outside? Do the egress requirements pertain to outside gated areas? Does distance from a building and a "safe refuge" come into play?
Any help would be appreciated!
