Pool installation with electrical completely compliant, right down to the required twist lock receptacle (pump location 6' from edge of pool) and timer as required by the energy code. The owner wanted to use his old pool pump motor so he made an adapter cord that he plugs into from the existing cord with straight, typical knife like plug to the required twists lock. The existing cord is 36" and the adapter is 12".
This is the setup you see for the final inspection.
Can you approve this under the IRC or NEC?
Why or why not?
Why or why not?
