Projections into door maneuvering clearances
Mr. Inspector
Poconos/eastern PA
IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG IMG_3104.JPG IMG_3105.JPG IMG_3106.JPG
The code is not clear about protrusions into the door maneuvering clearances. I know if something like a j box causes the door to be recessed it can't be there. usually when there is a thermasate there I tell them to move it but I am looking at some thermostats that don't protrude more than a toggle switch
The 3rd photo is a 2 1/4" surface box that will have a 2" deep fire alarm mounted on it that is 82" high and the door is 100" high.
I am confused about how far an object can protrude into the door maneuvering clearances.
I think you mean up to a 8" recessed door. I know if you have a object in the maneuvering space that would stick out over 8" past the door face would make the door not comply on the pull side and push side if there is a closer and latch but is there a different rule for projections into the clear floor maneuvering space then there is for a circulation path?
An 8" projection is OK if it's not in the circulation path. Projections are limited to 4" if you have to turn and walk along the wall next to the door.
When trying to understand a Code section, I find it helpful to think about what that section is trying to accomplish.
Can someone who is mobility impaired approach and open the door?
