This is under the 2006 IBC. I'm asking this as a designer, not a code official. The office I'm in "inherited" this project from another architect and some buildings have already been reviewed and are under construction. An 3-Story, R2, two bedroom, Type 5A stucture. NFPA 13R supression. The dwelling units do not share common exits...everyone has their own front door. Some of these front doors are facing each other within what is essentially a breezeway, namely an exterior space under the upper level floors and open at each end. An occupant can therefore exit their unit and turn left or right to travel on to "a street or public way". The minimum width of this breezway is 6 ft. The exterior walls and floor/ceiling assembly above are rated for 1 hour and these front doors are rated for 45 min. As I stated above, some of these buildings (which vary from 10, 15, 20 and 25 unit configurations) have already been given permits and are under construction. what hasn't been reviewed yet (but I believe has been discussed with the authority having jurisdiction) is that in a handful of these ground floor units have a third bedroom with a single 2x3 nom. unprotected window facing into this common breezeway. This is at only one end of the breezeway. This is one of those rare occassions where I think everyone else is being too liberal. Because the occupants are not at a street or public way when they walk out of their front doors but have to continue for a distance of 20-30 ft depending on if they turn left or right, I think this breezway serves the function of an egress court (1024.5). Does the fact that going past that opening isn't an occupant's only choice have anything to do with it being unprotected? Sorry this was so long and I hope I made myself clear.
_Bldg 900 - A2.1 A-2.pdf
