TimNY
Platinum Member
I don't think this is according to their approval
I've never seen one but I think they are called MiniMicrolam.TimNY said:The span from the beam to the top of the photos is about 16 feet. Then the Microlam (which they ripped down to make flush) is spanning about 12 feet. It is like a trampoline upstairs.
That's the same thing I thought. They thought it was stringer if they were nailed together. Maybe so, maybe not. I'm just an inspector.incognito said:Why did they "sister" along side the original floor joists? It appears that the original framing is at least 24"o.c. Might have worked if the new floor joists would have been installed midway between the existing floor joists.
I do see your point of putting the shim in the middle so that the nails at the side of the hanger hit a joist, but a longer nail should suffice.fatboy said:Add the shim, if the spacing block was in the middle, I might have ignored it. But it still isn't going to fall within the listing for the hanger. Sure, it will work, but???????
