Robert Rudy
Permit was issued through being a duplex should had hearing was planning and zoning but this was administrative done and permit issued at that point having a set of plans freedom of information act have plans architectural e at first these plans show doorways going through firewall on a zero lot line the also have no sheetrock on the detail of each inside 1 hour fire wall they also have a second kitchen in one of the duplexes details on documents ie, fireplaces gas or electric or propane or same thing with all four hot water heaters. This duplex is 10675 sq feet on all 16 corners zoning g r l. Also doorways going through firewall or party wall on two different levels on the third level they have Dex that they can walk from one side to the other side and doorways connecting these too close to firewalls and one portion of duplex is over the other portion of deck backyard. And 1 unit has two kitchens in our municipal code guest room as labeled Hugo two definitions of guest room at the end of the sentence and not allowed any kitchens the city has been ignoring this for 6 months now and I've hired an attorney an engineer and a local architect we've also learned of possible fire flow issues at Street hydrants as you know this size building needs fire sprinklers our streets where installed in the 60s and they have 6in dead end water services the other interesting thing is they have water lines going over property lines of each other because two weeks after getting permit the file to make these townhouses .Please all help needed with this bad situation the other interesting thing is my house has two windows on property line. Will try downloading plans architectural, engineering, engineering calculations thanks I've been using this website to get things started with attorney and engineer
