The basement would be considered a story, wouldn't it? So Three stories if there was a basement and a habitable attic would most often (in my area) be two stories above grade with exterior walls on all sides, and the attic. That is pretty much what I have here already. Granted, if there were no basement (say if it were a crawlspace . . . . )peach said:The "habitable" attic will require a code compliant stairway... and an egress window.. and a smoke detector.. whether it's a finished space or not.You're actually also looking at a potential (essentially) 5 story house (basement, 3 stories and this attic)... of course, you'll also see a residential fire sprinkler installed.
Even with zoning restrictions, the designer may rely on the IRC (only to get shot out of the water).
Beg to differ, what the IRC covers does not mention if the storiess are above or below grade. It simply says "not more than three stories in height"georgia plans exam said:The IRC applies to stories "above grade."IBC Table 503's height and story limitations apply to "above grade."
Sprinkler increase applies to stories "above grade."
I don't believe basements count.
GPE
