Carpediem410
The jurisdiction uses the 2018 IRC.
There is a screened deck off the first floor (one story above ground level) with a set of 2 screened doors that exits to a set of stairs with the top step being flush with the deck.
The screen doors swing out over the steps.
There is no landing.
From the upper deck it is 34” vertically to the lower deck. There are 5 steps (I am counting the stair treads and including the top one that is flush with the upper deck).
This was all here when I moved in. The lower deck needs to be removed and rebuilt so a permit is required. Lower deck is on the garage side of the house, behind the garage.
R311.3.3 Storm and screen doors says “Storm and screen doors shall be permitted to swing over exterior stairs and landings.”
I have been told this means ONLY if there are two or fewer risers - see R311.3.2 Floor elevations at other exterior doors - even though the code section on screen doors does not include that language or refer to that section.
Is this the way everyone reads this section?
i was also told that reversing the swing of the screen doors will not solve the problem - because there are more than two risers. This seemed odd to me because in every house I have been in, the interior door to the basement swings in and there is no upper landing. Is this the way everyone reads this? Are there different rules for interior and exterior doors?
I am trying to find a code compliant solution that will not be cost prohibitive.
If I am stuck with the above rules, I see these as my code compliant options -
Remove the doors - now I do not have a screened in porch.
Remove the lower deck and replace the screen doors with a railing and balusters. I have a screened deck but no yard access.
Raise the lower deck so that there are only 2 risers from the upper deck to the lower deck. Expensive.
Build a freestanding deck extension outside the screened in deck where the existing lower deck is with stairs to ground level. More expensive but might look better.
Redo the entire thing (it’s all treated wood about 30years old - I have to stain it regularly - move to vinyl and trex) and run the deck the entire rear of the house (opposite side - not behind the garage) with French doors from the dining room (replace windows that are currently there) to an unscreened portion of the deck where I would put the gas grill and would have better kitchen access. Really really expensive but what I would have done if I had built the house.
I have no prices for any of these options - this is just my guess.
I am looking for any input, suggestions, thoughts.
Thanks.
Thanks.
