tbz
Silver Member
So here is the question that keeps coming back around the table, time and time again.
R311.3 requires a landing outside all exterior doors, except for when R311.3.2 exception 2 is met.
The exception in R311.3, says if the floor area is not over 60sqft then you are not required to have the full 36" minimum travel direction
However, it does not say, you can eliminate it fully.
So the common practice is to put guards across a door opening to nowhere, and if the 4-sphere rule is maintained not require a landing, but the more I look at this, where is the justification per code for nothing at all, and if nothing is not allowed, what do you believe is the minimum to be established, since the exception says it does not need to be 36".
