Rail mounting height
King
Rec'd elev shop dwg showing top of "handrail" inside cab @32"AFF.
Asked contractor why so low, contractor ensured it is code compliance. I asked him if he can lower it to b/t 34"-38"AFF. He said the AHJ would not allow.
I started to ask myself what is the purpose of this handrail? It is technically not a handrail because:
1-it is not 1 1/2" clear from the wall;
2-it is not circular in section
So what is the purpose of this "RAIL"? Is it bumper rail?
FYI, I looked in the local codes, and cannot find any requirement of mounting height.
Ada????
Not sure what the current height requirements are
NOTE: National Elevator Industries ( NEI ) standards recommend a support rail be provided on the rear wall of the car. The rail shall be smooth and the inside surface at 1 1/2" (38mm) clear of the walls at a nominal height of 32" (813mm) from the floor to the top of the support rail.
This one says 30
http://www.buildings.com/ArticleDetails/tabid/3334/Default.aspx?ArticleID=8347#top
One more with pictures
http://www.unitedelevator.com/ada-upgrades/
Thx for replying.
ADA handrail mounting ht is 34"-38". Your 2nd article use the same #.
If the top of the rail is @32", it basically is too low to be used as "HANDRAIL" because it sits right below the buttock.
King said:
Thx for replying.ADA handrail mounting ht is 34"-38". Your 2nd article use the same #.
2010 ADAAG Advisory 403.6 Handrails. Handrails provided in elevator cabs and platform lifts are not required to comply with the requirements for handrails on walking surfaces.
