BayPointArchitect
Sawhorse
A convenience store owner wanted a covered drive thru adjacent a pass thru window.
The drafter thought it would be clever to put in garage doors and enclose the drive through during hours when the business is closed.
With good reason (LSC 36.1.1), FM denied the permit unless the entire building and covered area are sprinkled AND a one-hour rated wall is installed - complete with fire-rated glass between the drive-thru and convenience store.
Given a fully sprinkled building and one-hour rated barrier, we are trying to re-design an "equivalent level of safety" to avoid the fire rated pass-thru window.
Question #1:
Provided that the garage doors are removed and the covered roof over the drive thru is supported by a wall with large openings, how much area of that exterior bearing wall would need to be "open" for this to be considered a non-hazardous area rather than an enclosed parking area?
Question #2:
Does the LSC also have provisions for non-separated and most-restrictive occupancies similar to the IBC?
Thanks
Question #1:
Question #2:
Thanks
