Rated walls
Hang on.... depends on why the rated wall exists. If a fire wall is used to create separate buildings or a fire barrier is used to reduce fire area, then rating is higher.
Fire wall would be 3hrs per Table 706.4
Fire barrier would also be 3hrs per Table 707.3.10
I would double check the type of construction given that type 1 construction requires either a 1 or 1 1/2 hour rated roof assembly for the F-1 occupancy.
