Dave in WI
I have a situation where it would be beneficial to consider an existing 12" thick stone masonry wall as 1-hour rated. The wall is made up of 4"-8" diameter stone (no idea what KIND of stone) solidly mortared together to a roughly 12" thickness.
(The reason why it would be good to consider it rated is for the installation of a handicapped accessible lift. It would be installed in a "notch" in the building, and it would JUST fit if we skim coat the existing stone wall. If we need to furr it out with gypsum board or shaftwall, it won't fit, it's that close. 708 requires a shaft to be 1-hour rated for this, a 2-story building.)
I've looked at calculated resistance in IBC, and the ratings of archaic materials in IEBC. However those generally address CMU, brick or clay tile masonry, not stone.
Common sense tells me that if this building were to burn down, this stone wall would be the only thing left standing. However I would like to be able to go to the AHJ with something to point to besides this. Anyone have any ideas, ever run across this before?
