Receptacle Height in Basement
Brian Kimbark
New York
Hi all,
I am working on finishing my basement (Location: Pleasant Valley, NY) and was trying to find the code that states what the height of the outlet receptacle should be. I wasn't sure if this was a general code, or a specific basement code.
Any help would be much appreciated!
Thanks,
Brian
Might wait a few days for other replies
210.52 Dwelling Unit Receptacle Outlets
This section provides requirements for 125-volt, 15- and 20-ampere receptacle outlets. The receptacles required by this section shall be in addition to any receptacle that is:
  1. Part of a luminaire or appliance, or
  2. Controlled by a wall switch in accordance with 210.70(A)(1), Exception No. 1, or
  3. Located within cabinets or cupboards, or
  4. Located more than 1.7 m (51/2 ft) above the floor
Permanently installed electric baseboard heaters equipped with factory-installed receptacle outlets or outlets provided as a separate assembly by the manufacturer shall be permitted as the required outlet or outlets for the wall space utilized by such permanently installed heaters. Such receptacle outlets shall not be connected to the heater circuits.
Informational Note: Listed baseboard heaters include instructions that may not permit their installation below receptacle outlets.
(A) General Provisions
In every kitchen, family room, dining room, living room, parlor, library, den, sunroom, bedroom, recreation room, or similar room or area of dwelling units, receptacle outlets shall be installed in accordance with the general provisions specified in 210.52(A)(1) through (A)(4).
(1) Spacing
Receptacles shall be installed such that no point measured horizontally along the floor line of any wall space is more than 1.8 m (6 ft) from a receptacle outlet.
(2) Wall Space
As used in this section, a wall space shall include the following:
  1. Any space 600 mm (2 ft) or more in width (including space measured around corners) and unbroken along the floor line by doorways and similar openings, fireplaces, and fixed cabinets that do not have countertops or similar work surfaces
  2. The space occupied by fixed panels in walls, excluding sliding panels
  3. The space afforded by fixed room dividers, such as freestanding bar-type counters or railings
Around 15” or so.
For ADA compliance, operable parts need to be between 15" and 48". ADA regulations are probably irrelevant in your basement, but it is another factor to consider.
The electricians I know like to put theirs about 18" off the ground, but really it's just your preference.
One factor to consider when determining how high to put the receptacles is what is your you're going to be used for. If it's going to be a shop higher up (48"or so) would be easier to access the plug and unplug tools.
