OK, how would you handle this one?
A condo ceiling is being renovated with new drywall. There is no attic above so once drywalled, there is no access. The electrician is installing LED recessed lights with separate drivers that get plugged into. By design, the driver fits into the hole cut for the spring loaded light. The driver is then able to be removed by reaching up into the hole after removing the light and unplugging it from the driver connector. The house wiring should be long enough to allow the driver to be removed and replaced. In this case, the driver gets connected to MC cable but to make it easier for the sheetrock contractor, they screwed the drivers up into the ceiling because they realized there is not enough room to slip the driver up after wiring it due to the shallow depth. This creates an issue where once the drywall is in place and a driver needs to be serviced or replaced, it cannot without cutting out drywall therefore making it no longer accessible.
