beach
I have a large hospital complex that has a separate building used for child daycare, the hospital wants to reduce or eliminate the audible notification in the day care and use the existing visible signaling per 2010 NFPA 72 Section 18.4.3.2 "Where approved by the authority having jurisdiction or other governing codes or standards, the requirements for audible signaling shall be permitted to be reduced or eliminated when visible signaling is provided in accordance with Section 18.5."
Assuming the daycare visible signaling is in accordance with Section 18.5, does anyone see any problem in allowing the audible reduction or elimination?
The reasoning, according to the hospital, is that the audibles are scaring the children and causing nightmares according to the parents, and they are also concerned about long term affects to their hearing.
Due to ongoing construction, etc. the false alarm rate is approx. 20 times per month.... this is another problem we are dealing with.
I'm leaning towards allowing the audibles in the childrens rooms (approx. 8 rooms) to be reduced or eliminated, and using only visibles per the above reference, and keep the ones in the main office. Naturally, there is a "teacher" in every class when the children are present.
Any thoughts or recommendations would be appreciated!
