Robert Ellenberg
Chapter 34, Electrical Definitions, defines a LIGHTING OUTLET as an outlet intended for the direct connection of a lampholder, a luminaire (lighting fixture) or a pendant cord terminatin in a lampholder.
Section E3803 requires one in every habitable room except you can have a receptacles controlled by a wall switch in other than kitchens and bathrooms. I have selected approved fixtures I wish to install in a kitchen that look like track lighting but they have a cord on the end that plugs into an outlet. I was going to build a dropped box on the ceiling with an outlet in it, plug the cord in and mount the fixture on the bottom of the board. But in a strict reading of the code, the definition says it must be a direct connection. If I cut the plug off and make a direct connection, then I have voided the UL approval of the fixture.
This appears to be one of those items that falls through the cracks. Do any of you electrical inspectors have a different interpretation or would you approve this?
