requirement for the height of street fire hydrants
sunyaer
Toronto
Is there a requirement for the height of street fire hydrants in Canada building code (including OBC) or fire code?
I measured the height of a few fire hydrants on the streets in Ontario, the height from ground level to the center of hose connection range from 18" to 31".
Don't know aboiut Canada. Here in the USA 18" to 36" at the center-line of the 4" connection is typical. Some jurisdictions say to the center-line of the lowest connection. Some do not provide a maximum dimension.
There may be an NFPA standard on that, but in the U.S. neither the building code nor the building-related fire safety and fire prevention codes address hydrants, for the simple reason that they're not part of the building.
Typically, we just make sure they are acceptable o our fire fighters. There must be an NFPA standard on it though...
