Redmund
If fire barriers or fire partitions occur on an upper level of a Type V-A building, the construction supporting these fire barriers/partitions is required to also be rated to the same hourly rating as the fire barriers/partitions that are being supported (IBC 707.5.1 & 708.4.1).
However, the code doesn’t specifically say that the walls that are a part of the supporting construction shall be installed as fire barriers or fire partitions, but is that the generally accepted practice? It will make a difference as to how any openings in the lower level rated supporting walls will need to be treated. That is, openings in a wall required to be rated just by IBC Table 601 only are not required to be protected, but what about the openings in walls that are supporting an upper level fire barrier or fire partition?
