Would asphalt shingles be a protective roof covering?The code does not say "...over asphalt shingles"
R908.3.1 Roof Recover
"...The application of a new protective roof coating over an existing protective roof coating, metal roof panel, metal roof shingle, mineral surfaced roll roofing, built-up roof, modified bitumen roofing, thermoset and thermoplastic single-ply roofing and spray polyurethane foam roofing system shall be permitted without tear-off of existing roof coverings...."
Maybe it was: R908.4 requires the entire existing surface to be covered with gyp board, mineral fiber, glass fiber or other approved material.I recall reading somewhere that under certain conditions the space between the metal roof and the existing roof shall be fire-stopped. It might have been if the existing roof was wood shingle or shake.
Wouldn’t the existing shingles provide a suitable fire resistant surface?Maybe it was: R908.4 requires the entire existing surface to be covered with gyp board, mineral fiber, glass fiber or other approved material.
In my read of that section, they are defining what a protective roof coating is. Otherwise they would not have listed any of those other, protective roof coatings.Would asphalt shingles be a protective roof covering?
Good advice & best practiceAfter re-reading the relevant code sections I see that this is yet another interpretation based call. I think it comes down to the manufactures instructions. If a licensed contractor showed me that their product can be installed over shingles I would probably have to approve it. However, I think it's a bad idea. Without a tear-off you don't really get a good look at the decking, you don't replace any flashing or flues, and if there is unseen damage it will be much harder to track down and repair later. If someone wants to invest in metal roofing (vs replacing with another shingle roof) why not spend the extra money to be sure the decking is solid, flashing replaced, proper underlayment installed, etc... But to each their own I suppose.
Ya I'm not with you on that. Asphalt shingles are a protective roof covering and the most likely candidate for a first and second layer.In my read of that section, they are defining what a protective roof coating is. Otherwise they would not have listed any of those other, protective roof coatings.
