Residential Grade Beams
We don't have quite the same number of piles, but this foundation is similar to what you find on the Colorado front range, at 5280 ft. Due to expansive soils, deep drilled piers hit bedrock many, many feet below and then grade beams that are full height foundation walls are place on top. Cardboard void forms are then placed at the bottom of the forms between piers so there is a physical separation from all the soil. Different issue, similar solution. Thanks for sharing. It's great to see construction practices from other regions.
That’s a lot of conduit! Is that near the electrical panels?
Seeing all that sand ... easy to dig. When we built in san antonio, they cleared a couple of inches of top soil, then built forms on top of the limestone rock. Setting fence posts was always a brutal job.
I would have expected the rebar to be bent 90° at the top of the pile. But I am in California where the ground moves. We have caissons and they are always much larger in diameter. Public works projects like bridges will sometimes drive piles but I don't see them. Working with sand dictates what is possible. I suppose that our beach communities drive piles too. That's got to be a less than fun job.
