Residential ramp
jtom
Sawhorse
Va.
We have a small den addition being built where they want a ramp out of this addition.There is already a required egress door in another part of the home.The plans are stating this is not an ADA compliant ramp,but R311.8 requires a maximum slope of 1:12 or if site restrictions a 1:8.There seems to be no site restrictions,so I believe a 1:12 ramp is required,even though the owners want a steeper slope.How do others feel about this?I say the code is specific on this point.They want a 3:12 slope.
I sense an attic stair thread about to unfold.....
I agree 1:12, or 1:8 is required BUT, is this the primary entrance? No.
You state compliant egress is already provided elsewhere. I'm curious, what is the elevation difference?
If it's under 30" I may be willing to allow a steeper slope.
Call it a crooked deck and a permit might not be required......
10. Decks not exceeding 200 square feet (18.58 m2) in area, that are not more than 30 inches (762 mm) above grade at any point, are not attached to a dwelling and do not serve the exit door required by Section R311.4.
Bad idea, but they might get what they want and I am not liable when they get what is coming to them.....Everyone wins!
Ramp requirements per 311.8 apply wherever they occur, similar to stairs. 1:12 is applicable and should be the standard for construction.
To play devils advocate....what is the max slope for floors or decks?
5 % then it is no longer a floor or deck it is a ramp
RAMP. A walking surface that has a running slope steeper than 1 unit vertical in 20 units horizontal (5-percent slope)
Good call MT....In that case it is an architectural cover that I store my garden tools under....And/or still refer back to my earlier exemption
"We have a small den addition being built where they want a ramp out of this addition."
jtom,To inquire a little further, ...but who is the "they" who is wanting the ramp constructed
out of the addition ?.........Is it the Contractor, ...the homeowner, or other ?
RE: actual useability of a ramp is my point...........Minimum of 1:12 is just that, the minimum.
A ramp can be constructed to be easier on the user, ...saaaaay, 1:20...........Is it required,
No !..........But it is user friendly & practical...........I'm thinking about the person(s) who
will actually be using the ramp.
3:12 is more of a slide then a ramp
Intended use is a consideration... I was thinking the same thing as Francis Vineyard, build steps and cover them with plywood after final.
They'll get what they want and the AHJ will get what the Code requires.
