roxas
Hi,
Working through a code study on a restaurant remodel and was curious about gross area calculations in a commercial kitchen as required by CBC 1004.5. The kitchen itself has walls separating areas of prep and dishwash and offices.
As a gross area, they would need to be calculated as per the definition below, although the definition really seems to be more about the gross building, not gross spaces.
FLOOR AREA, GROSS. The floor area within the inside perimeter of the exterior walls of the building (emphasis mine, on "building" not "space") under consideration, exclusive of vent shafts and courts, without deduction for corridors, stairways, ramps, closets, the thickness of interior walls, columns or other features. The floor area of a building, or portion thereof, not provided with surrounding exterior walls shall be the usable area under the horizontal projection of the roof or floor above. The gross floor area shall not include shafts with no openings or interior courts. (Weird that is isolates shafts but not walls)
In the past I have normally calculated each room in a kitchen as gross, but am on the cusp of an occupancy issue and I don't want to get burned if I have to add up all the walls and poche spaces. Similarly, at a front of house bar, where does the gross perimeter end? At the back side of the die wall between the staff and customer, or at the back (kitchen side) edge of that bartop? There seems to be a gray area here. I never count the bar surface in my net A-2 calcs, but do I need to include it in my gross kitchen calcs?
For the restaurant front of house (A-2 Occ), I have seen many cases where movable tables aren't counted, but chairs are. And other cases where the access aisles or circulation are not counted and times when they are. Is there anything definitive on this? I have tried to look elsewhere online, but I have only seen the the basics, and nothing delving into this type of specificity.
FWIW, I am actually that close on my numbers, but I also just want this particular line of thinking verified with smarter folks than myself, for now and the future. Thanks!
