1103.2.2 Employee work areas. Spaces and elements
within employee work areas shall only be required to comply
with Sections 907.5.2.3.1, 1009 and 1104.3.1 and shall
be designed and constructed so that individuals with disabilities
can approach, enter and exit the work area. Work
areas, or portions of work areas, other than raised courtroom
stations in accordance with Section 1108.4.1.4, that
are less than 300 square feet (30 m2) in area and located 7
inches (178 mm) or more above or below the ground or
finished floor where the change in elevation is essential to
the function of the space shall be exempt from all requirements.
1103.2.6 Raised areas. Raised areas used primarily for
purposes of security, life safety or fire safety including,
but not limited to, observation galleries, prison guard towers,
fire towers or lifeguard stands are not required to comply
with this chapter.
[BE] EMPLOYEE WORK AREA. All or any portion of a
space used only by employees and only for work. Corridors,
toilet rooms, kitchenettes and
break rooms are not employee
work areas.
Toilet rooms are not employee work areas or not used primarily for purposes of security, life safety or fire safety so the toilet room is not exempt but the rest of the guard shack can be exempt if 7" above the ground but not if the guard also uses the space to take breaks
