BayPointArchitect
Sawhorse
Applicable code sections:
2012 IBC 1022.4
Openings in interior exit stairway [and subsequent horizontal exit enclosure] other than unprotected exterior openings shall be limited to those necessary for exit access to the enclosure from normally occupied spaces and from egress from the enclosure. Elevators shall not open into interior exit stairways and ramps.
2012 NFPA 101 Sections 7.1.3.2.1 (9) and 7.2.1.1.3 says the same thing using different words.
Looking at the attachment,
The stairway is highlighted in green which leads or extends into the yellow horizontal exit which leads to the exit discharge. Along the path of the yellow horizontal exit, there is an elevator. The code is clear that "elevators shall not open into interior exit stairways...". Because the existing 2 hour fire-rated stairway will dump into the newly proposed horizontal exit, the same protection required by the green stairway needs to apply to the yellow corridor. Therefore the elevator may not open into this horizontal exit. But what about the restrooms? Sometimes we reason that there is not much to burn in the restroom except for the paper towels. And that would not amount to much of a problem. And some people spend a lot of time in the restroom. So how many of you code officials would say that a restroom can not be contiguous with the same air space of a stairway or horizontal exit? How many of you would say that a restroom is a normally UNoccupied space?
As always, thanks in advance!
ICC Certified Plan Reviewer
NFPA Certified Fire Plan Examiner
2012 IBC 1022.4
