Ridge Board to Hip Rafter(beam) Support
So who requires a support post at the top of the hip rafter to ridge board connection and when?
I am talking vertical support from the connection to a load bearing wall or point.
It's hit and miss whether or not that connection is over an area to drop a vertical support. Otherwise it may need it's own special little beam from wall to wall. No much of an issue in a hallway, but pretty big-time in an open room.
Brent.
"So who requires a support post at the top of the hip rafter to ridge board connection and when?"
I have seen 3 and 4 hip rafters meeting at a point being connected to the ridgeboard without any vertical support from underneath [ the spans weren't that
long though ! ].
Yes, good news in Cancun........gazing out over the pristine blue waters of the Caribbean, sipping on Kahlua and coffee.
To be honest we just don't see stick roof/rafter framing anymore, would have to see it to evaluate it.
Back to the coffee........... :)
The hips thrust, if the jacks are tied both ways, no vertical support is needed just as in a ridgeboard roof. if they are not tied then a post is needed, just as in a ridgebeam roof. If the perimeter top plates are designed as beams and if the corners are connected well that designed solution can avoid ties or post.
