Roof Coating
Inspect72
Illinois
I am curious if anyone is familiar with or has insight related to Tremco Alumanation 301. A company is asking to install this on the existing roof. I believe this product does not have a fire rating. Nothing related to the structure is changing just adding the coating. Curious if you would allow this to be used. Any thoughts would be appreciated. IBC/IFC 2018 codes. https://www.tremcoroofing.com/products/alumanation-301
If the existing roof was metal, I would assume two things. It probably had a factory coat of paint on it when it was installed. That factory coat of paint also did not have a fire rating.
It's aluminized paint. It's been used for decades. I've seen it on a lot of roofs and I've never even thought about code conformance.
The question was asked by the company putting it on asking for an approval by a fire code official which struck me as odd. I was more curious why they would ask for that and if I was missing something obvious.
Product is solvent-based flamable and does not have a fire retardent rating. there are roof coating specifically rated for flame retardent.
803.4​
The required flame spread or smoke-developed index of surfaces in existing buildings shall be allowed to be achieved by application of approved fire-retardant coatings, paints or solutions to surfaces having a flame spread index exceeding that allowed. Such applications shall comply with NFPA 703 and the required fire-retardant properties shall be maintained or renewed in accordance with the manufacturer’s instructions. The fire-retardant paint, coating or solution shall have been assessed by testing over the same substrate to be used in the application.
