MA_Architect
I am designing a small automotive repair garage (S-1), but I will have 165 gallons of class II flammable liquid (motor oil). If you have more than 130 gallons you are considered H-2 Rather than classify the building as an H-2, can I simply build a rated room to store the oil in? If so, please help me figure out the wall ratings. I can't use Table 508.4, because it obviously states that a separation is not required. I am thinking that I need to use Table 602, and assume I am building two buildings with a 0 lot line. This would make my rated room 2 hours. My goal is to have 110 gallon of "new" oil in the room, and allow the used 55 gallon drum to be moved around freely in the repair bays to capture all the old oil as required.
