Then I'm with the others, needs to be accessible and posting the sign is not providing the same equivalent.jar546 said:The counter itself is not 21 years old............
The building department would not have anything to require modifications, if nothing else is being doneCodegeek said:If the business has been there for 21 years and has done nothing that would require a building permit, when what would require them to provide compliance for accessibility?
Correct.....but ADA would still govern....and....105.2 Work exempt from permit.Pcinspector1 said:The counter could have fallen under Sec. 105.2 (13) "Work exempt from permit" and may have never crossed the inspectors desk? pc1
UNLESS THE MAT IS FIRMLY ATTACHED, IT IS A TRIP HAZARDsteveray said:What is the violation for the mat?
Does not matter it is a hazard.Pcinspector1 said:36.304 Removable Barriers? or 302.2 Carpet? pc1
Really?mark handler said:the carpet/mat is a violation, unless permanently attached to the floor
According to both ADA and A117.1 in Section 302.2, carpet is to be securely attached.mjesse said:Really?I see those everywhere around here (not implying that makes it legal)
Especially in the winter months, the snow and salt being tracked in to hard surface areas is a major slip hazard. Stores/malls/offices have multiple mats at the entries which are changed out several times a week by specialty mat companies here.
View attachment 837mark handler said:Really, A major slip hazard.Must be securely attached to floor
A lot of Things have change since August 13, 1992.mjesse said:Found this via Googlehttp://www.justice.gov/crt/foia/readingroom/frequent_requests/ada_tal/tal182.txt
So, maybe? If floor mats are not actually built-in as a part of a building or facility, they will not be subject to the provisions of the Guidelines ...
Even though the requirements of the Guidelines would not apply to the mats themselves, the Guidelines can provide
helpful guidance in ensuring that mats do not constitute barriers.- W. Lee Rawls, Assistant Attorney General
