globe trekker
- Joined
- Oct 19, 2009
- Messages
- 1,739
Yes, it's time for another poll!
Section 405.5 in the 2006 IPC requires that "Joints formed where
fixtures come in contact with walls or floors shall be sealed."
The IPC Commentary states that "the seal can be in the form of
plaster of paris, grout or silicon."
In some former discussions, some have not required / inspected
for these seals (i.e. - at the urinals, lavatories and the water
closets).
POLL QUESTION #1: Does your jurisdiction require / inspect for
these fixture seals (RE: Section 405.5 in the IPC)?
POLL QUESTION #2: If you answered "yes" to POLL QUESTION
#1, do you seal all the way around the water closet fixture, or
leave a small gap at the rear for identification of a sewer gases
/ failed wax rings? If you answered "no" to the POLL
QUESTION, ...thank you for playing along and kindly return
to your seat.
POLL QUESTION #3: If you DO require the sealing of all
plumbing fixtures, what do you typically use / require?
I know that I posted this topic in the Commercial section,
but do you what about your Residential applications?
What, if anything, do you do on the Residential side.
Thank you for playing!
Door prizes will be awarded at the end of the
polling!
closets).
to your seat.
polling!
