Section G2407 - 2006 IRC
globe trekker
I have an HVAC unit installed in a Hall closet in a new residence. Presently, the
combustion air is is proposed to be taken from the attic spaces by the means of
2 separate ( communicating air ) 6" round ducts. 1 is within 12" from the closet
ceiling and the other about 18" or so from the bottom of the closet flooring.
These ducts terminate in the attic space.
QUESTION: Can the required combustion air from the attic be used as to
supply this appliance? ( RE: G2407.6.1 ). The attic has eave vents and a
ridge venting system installed.
Thanks ya'll! :)
yes see but be carfeull with blown in insulation getting into the vent opening
FIGURE G2407.6.1(2) [304.6.1(2)]
ALL AIR FROM OUTDOORS THROUGH VENTILATED ATTIC
(see Section G2407.6.1)
Thank you both for your quick responses! I looked and looked for that particular
Figure " mtlogcabin ", but could not find it.
