Hi All,
I frequent this forum but this is my first post. I need help on a project I'm working on, it falls under the 2015 Seattle Building Code (amended from 2015 IBC).
The project site has liquefaction soils and our building foundation is supported by 60-90' deep auger cast piles. There is an independent, pre-fabricated below-grade stormwater detention vault that is outside of the building footprint, below a surface parking lot. Our code reviewer is stating the stormwater detention vault needs to be designed for potential geologic and seismic hazards (including seismic lateral earth pressures and differential settlement due to liquefaction). The Geotech report notes up to 15" of post earthquake liquefaction so that would require us to install the below-grade detention vault on a deep pile foundation similar to the building.
The reviewer has referred us to the 2015 Seattle Building Code (SBC) sections 1803.5.11 and 1803.5.12 for additional information and stated that they do not allow exemptions for underground water storage vaults or structures that are typically unoccupied.
However, this code section lists the requirements for the Geotechnical investigation, which were included, and doesn't note how the seismic requirements are applicable to below grade structures.
I believe the storm water detention vault should fall under the local stormwater management design manual which only states 'Detention vaults shall be placed on a stable, well-consolidated foundation and bedding material.'. I believe this rational is supported by the fact that none of the other site elements (retaining walls, electrical vault, electrical transformer pad) or the other stormwater infrastructure elements (catch basins, connections, up/down steam pipes) are designed for liquefaction settlement. Furthermore, the parking lot this is located under is not designed for liquefaction settlement.
Does anyone know of any code exemptions that exclude below-grade/unoccupied or stormwater structures from seismic requirements?
