Separation of elevators in single hoistway
redeyedfly
Minneapolis, MN
Where can I find the code which requires separation of multiple elevators in a single hoistway? I don't mean 3002.2, I'm referring to the steel mesh spanning vertically between divider beams.
I can't find the requirement in IBC Ch. 30 or ASME A17.1
Interesting.......I have never heard of this.
Probably because there is no requirement. I have written specifications for several hundred elevators over my career and never once was I asked or required to put steel mesh between hoistways.
The only reason I can think of such a requirement is for security reasons. Some elevators within a single hoistway may serve floors that have restricted access. To prevent someone from accessing a restricted floor from a non-restrictive floor without adding the cost of a full wall, some may use metal mesh. Think of an elevator used in courthouses where one elevator is for the public, one for the judges, and one for prisoner movement. They may be within the same hoistway for cost reasons, but you do not want prisoners in one elevator car to be able to access another car within the same hoistway and escape.
Bump, has anyone else seen this?
I've seen it on two different projects on opposite ends of the country, never saw it before. Best I can find is the CA code and I'm not even sure where that section of code applies.
The California requirement is a Cal-OSHA requirement and not a building code requirement. I could not find another OSHA or building code requirement for hoistway separation.
Was it a Cal-OSHA requirement for safety when working in the hoistway with an operating car?
