Typically...here in CT...what has been commonly accepted is probably 5 to 7 feet of cable inside to the disconnect....there are electricians that say that there is some magical 10' rule (so that must be acceptable in some towns) (I believe there is one for feeders)...I tell them as short as possible...I figure if you enter under the meter and drop straight down into the top of the panel, should be maybe 3 to 5 feet and should be acceptable, anything more than that will be taken on a case by case basis...saw one the other day on a garage (that was approved by my boss) w/ meter can on outside no disco, panel in wall on inside with about 5' of SE cable looped inside the wall, which will then be covered with drywall....Hope they don't hang anything on that wall....!
