Service countertops
mark handler
So. CA
Serv-A-SYST revolutionizes restaurants, bars and other points of service solving the ADA requirement for a lowered portion of countertop. Service countertops can now be easily moved between two positions to satisfy the needs of all customers. Approved for granite, marble, wood, metal and solid surface counters. Controls movement of countertop height, from 42”" to 32”", by neutrally balancing the weight of the surface.
Code Compliant
Meets requirements of ADA Accessibility Guidelines pertaining to service counter areas
Effortless Operation
Neutralizes the weight of moving bar or countertop surfaces
Smooth Motion from High to Low
Holds securely in high, low and in-between positions
Maintenance Free
No compressed gases, oils or power requirements to worry about
Seamless Integration
Accommodates most bar, countertop and under bar equipment designs
Serv-A-SYST
