Service Sink ? ? ?
Mech
Eastern PA
2009 IMC / IPC
Would hot and cold water faucets and a floor drain in a mechanical room meet the requirement for a service sink?
Are there curbs surounding the room?
"Not a IPC definition"
A water basin fixed to a wall or floor and having a drainpipe and generally a piped supply of water.
IMHO NO
No curb around the room. Yeah, no spill / splash containment when emptying a bucket.
Out of curiosity, where did you get that definition in the IPC? I didn't find it.
Thought you were saying my scenario did not meet the IPC definition which you were providing.
Reread my response
I never said it was a IPC definition.
You might want to read the footnotes on table 403.1 IPC re: service sinks
Is a floor drain and a faucet defined as a sink. NO
Got confused by what you meant with this definition. My mistake.
My copy of IPC Table 403.1 footnotes do not address service sinks. Oh well. The building will be getting a service sink.
Thanks for the input.
I would not consider a floor drain to be suitable alternative for a service sink. In certain circumstances, we have permitted floor sinks in a raised curb area with protective finishes on the wall to 4' aff, but that is rare.
So if I put a sink in my shop, with a drain pipe going outside, would that be a service sink? What if the drain went to a grassy area?
2009 IPC, Section 418 - Sinks Sinks shall conform to ANSI Z124.6, ASME A112.19.1M, ASME A112.19.2M, ASME A112.19.3M, ASME A112.19.4M, ASME A112.19.9M, CSA B45.1, CSA B45.2, CSA B45.3 or CSA B45.4.
2009 IPC Connections to the sanitary drainage system. All plumbing fixtures, drains, appurtenunces and appliances used to recieve discharge liquid waste or sewage shall be directly connected to the sanitary drainage sytem of the building ....
We also adopted the ANSI Z4.3 for Non-sewered waste discharge, in order to handle some instances of grey water discharge.
Is it more a more detailed/helpful than the grey water provisions of Appendix C in the IPC?
That's a lot of alphabet soup. Do you have all of those wonderful standards, or do you refer to the manufacturers spec to verify all the right standards are listed? Are they all applicable to every type of sink? This is one of my pet peeves with the IPC, but then again "nothing worthwhile was ever accomplished without the will to start, the enthusiasm to continue and, regardless of temporary obstacles, and the persistence to complete." Time to order me-self some standards and get to it.
LOL, Papio! No, I don't have a copy of the standards. I feel your pain; it's just one more book that has to be on hand in order to enforce the code as a code official. It would be nice that since it's referenced in the I code that those folks who are ICC members could get a discount on all of those standards, and they may very well get that if ICC has the standard on their website. I know in years past ICC published the referenced standards in one document, but I'm not sure they do that any more.
It is not much different. When we adopted the standard the 09 was not out yet and the 03 app. C did not have seepage pits.
Mech, how big is the mechanical room? Slip hazard with soapy water IMHO would be a concern.
If the drain was close to a wall where the faucets are located and you had concrete type curbs inplace and tile with grout, I would consider it, but thats a reach. The curbs would have to be out of the walking path (not knowing the distance the faucets are from the drain) as well in the mechanical room. Good place to wash the dog!
pc1
