shower door height
darcar
Silver Member
Is anyone aware if there is a requirement for shower door height in a residential setting? Typically the top frame for a glass door will be set at 80"(6'-8") (same height as the tub surround). We came accross one today that someone mounted the top track and a person would have to duck down to 68" (5'-8") to get in and out if the shower.
If there is such a requirement, can you please include code reference (prefer IRC).
Also, what about interior doors accessing bedrooms, bathrooms, etc.?
Thanks in advance
Re: shower door height
P2708.1 General. Shower compartments shall have at least
900 square inches (0.6 m2) of interior cross-sectional area.
Shower compartments shall be not less than 30 inches (762
mm) in minimum dimension measured from the finished interior
dimension of the shower compartment, exclusive of fixture
valves, shower heads, soap dishes, and safety grab bars or rails.
The minimum required area and dimension shall be measured
from the finished interior dimension at a height equal to the top
of the threshold and at a point tangent to its centerline and shall
be continued to a height of not less than 70 inches (1778 mm)
above the shower drain outlet. Hinged shower doors shall open
outward. The wall area above built-in tubs having installed
shower heads and in shower compartments shall be constructed
in accordance with Section R702.4. Such walls shall form a
water-tight joint with each other and with either the tub, receptor
or shower floor.
Thanks. If I'm reading that right those dimensions are for the "shower compartment" and not addressing the door itself.
The shower door is a part of the compartment, matter of fact it's mentioned in the next sentence.
darcar,
Refer to Sections R101.3 - Purpose. & R305.1, #4 - Ceiling Height in the `06 IRC. Packsaddle gets the credit
for this reference! We've been down this road before, ...and now, again!
I think the point is that the compartment needs to be enclosed somehow. The door would need to be 70 inches high. If you wanted to put in a shower curtain, it would be mounted 70 inches high. I think that is an interpretive item though. Some ahj's may not agree but I think it is a good starting point.
