LGreene
Hollow metal frames are prepped at the factory for silencers - the small grey rubber mutes that make it a little quieter when the door closes. The holes are 9/32" in diameter, and they are on the side of the frame stop where the door contacts the frame. On single doors there are 3 holes, on pairs there are typically 2 holes, although some catalogs show 4 holes for a pair.
When a fire rated hollow metal frame has smoke gasketing that mounts in the same area as the silencers, the silencers are not installed and the gasketing is installed instead. This leaves the silencer holes open, although they would be under the adhesive gasketing. I have been asked if these "open holes" would be a deficiency on a fire door assembly, because one of the fire door inspection criteria is that there are no open holes in the assembly.
My gut reaction is that the open silencer holes would not be an issue because during the fire test the silencers would have melted away at some point, leaving the open holes, and the assembly was able to pass in that condition. Common sense tells me that having smokeseal installed over the holes wouldn't affect the performance of the assembly. But NFPA 80 doesn't address this specifically, and says that any open holes left after removing hardware have to be filled with steel fasteners (etc., etc.). There are definitely people out there who would not agree with my assessment that the holes covered by gasketing are ok.
What say you? Any logical arguments on either side of the discussion? If you're thinking this is a crazy question, welcome to my world.
Here's a catalog cut of a silencer: http://www.iveshinges.com/CatalogCuts/Ives-SR64.pdf
