What are the solutions to maintain safety for a large interior space A-3 Occupancy, open roof/clg at 30ft above the floor, sprinkled, with the following training props.
prop A) In the middle of the room a 10ft x 16ft x 16ft height raised wood framed platform with 4 columns (like a table), no storage underneath.
#1 Underneath 3 sides open and the 4th side is a climbing wall.
#2 Underneath 2 opposing sides open and climbing walls on the remaining sides.
#3 Underneath climbing walls on all 4 sides totally enclosed.
prop B) raised trampoline at 6ft height with adjacent ball pit.
Code says to drop and sprinkle under an obstruction that will delay activation or obstruct distribution pattern. Then defines the obstructions with items that have a use/activity/appurtenance underneath OR equipment. Dropping a sprinkler pipe down 15ft + is not reasonable due to stability, or functional durability due to the elements...being youthful elements.
thoughts:
prop A) Argument whether the climbing wall is not equipment has nothing to do with safety. Argument that the sprinklers are protecting the prop and since there is void underneath there is no activation delay or obstruction of distribution pattern - everything is protected.
prop B) This is equipment with no appurtenance or use in the void underneath. Adding sprinkler head underneath seems to be adding a hazard and ludicrous.
solutions:
Who thinks the training props are safe as-is without adding sprinkler head underneath? If not, what corrections would you propose to provide equivalent protection?
thoughts:
solutions:
- notice sign for violation if anything stored underneath
- add smoke detector underneath and tie to fire alarm system
- remove prop A) decking and replace with grate...remove obstruction
- other?
- other?
