Skirting and Underpinning
Jonathan Shoemaker
Texas
I am remodeling a house and have torn down all the skirting/underpinning from around it. I would like to replace it back and need to see what the requirements are. I can't find any info on skirting/underpinning in the international building code. I do random google searches as well and don't come up with anything useful. Maybe I am using slang and not the proper words. I am new to using the building code books, normally I would of just cut some sheet metal and placed them vertical all the way around the house, but we have a building inspector who is less than helpful who is coming around now. This is in Texas and there are no amendments to the local code.
Regular built house?
Not mobile home?
What is the measurement of this skirting from the ground up??
Why do you think it is needed?
Not mobile home?
It is a wood frame home, not a mobile home. The highest portion is 1-1/2 feet from the ground to where it will be hidden behind the siding. I feel it is necessary for cosmetic, hide pipes, shelter pipes, to keep animals from under the house, and all houses I see have skirting
So the house is built on piers?
Can you post a picture?
It's a pier and beam house. If that does not work, imagine a trailer house. I want to put skirting around it. I can't find the correct words to look up in the IBC to find out how to do it and the restrictions.
My guess would be no wood, but guessing almost anything else exterior rated works
Is the house in a flood plain, and/or are there flood-resistant design features required?
Most folks around here would use exposed-fastener barn metal in this application or, less frequently, that crappy vinyl mobile home underpinning.
Yes, that is exactly it.
I normal use tin roofing sheets, either vertical or horizontal. Now that I am being held to building to code, I am trying to figure out if that meets code. I however can't find anything for under pinning or skirting, which is what I call it. It could be called something else. I am trying to build it the "proper" way, so I am want to find it in the code book.
The big thing for crawl spaces is usually ventilation in order to prevent a buildup of dampness coming up from the soil below.
Our code allows ventilation to be through natural or mechanical means, minimum of 0.1 square meters of unobstructed vent area for every 50 square meters of floor area, the vents must be uniformly distributed on opposite sides of the building and designed to prevent the entry of snow, rain and insects.
Were this CA this might be considered Knee walls and they would require seismic reinforcement. In Tx I believe the concern would/should be both cosmetic, air ventilation, mold protection and vermin infestation protection. Most durable materials (some you have mentioned) would work. If it were up to Frank Geary he would just wrap it with chainlink or sheepwire.
