Sorry meant to say seems like you could built an efficiency under it one room4thorns said:1st floor has Kitchen, living, bathroom and office. 2nd floor is an open concept, labeled on plan as Open Loft. It meets space requirements for habitable area and has an egress window.With that said, the loft could be used as a sleeping area. It's just not labeled as such on the plans.
What are you quoting from?Inspector Gift said:"Sleeping room" (a room designed for sleeping purposes - no bed or closet required)"sleeping area" (an area where sleeping can take place - no bed or closet required)
"bedrooms" (a room where sleeping can take place - no bed or closet required)
"An enclosed room with a door and which appears to be designed for, or which could likely be used for sleeping and includes rooms which may be identified as; den family room, study, office,library, etc..."
It doesn't matter what they call it, if it is any of the above, it must have a smoke alarm. And every "sleeping room" shall have an emergency egress opening.
I think that is IPMC....Yankee said:What are you quoting from?
.steveray said:I don't know how we got on single room, but good point mark....
How would a single room occupancy encompass a kitchen and bathroom as a single room?mark handler said:Single room occupancy-SRONo need for egress window, you have a door.
You could designate the loft and sleep in the bathroom if you so choose.4thorns said:So essentially, I'm under the assumption after reading all the replies, that plans are required to indicate a designated sleeping area in some way regardless of the room designations. Tho it may seem rather odd not to designate a "Bedroom"(s), as long as a sleeping area is designated then all is good. Although I realize there are reasons not to label too many bedrooms! ($$$)If I bring you the set of plans for the house I described, and it contains 2 rooms that are suitable for sleeping (per code) then do I have to tell you which room I will actually sleep in on a permanent basis?
Gregg, the term "SRO" does not literally mean there is no bathroom. According to HUD's definition, "SRO housing contains units for occupancy by one person. These units may contain food preparation or sanitary facilities, or both." http://portal.hud.gov/hudportal/HUD?src=/program_offices/comm_planning/homeless/programs/sroGregg Harris said:How would a single room occupancy encompass a kitchen and bathroom as a single room?
