If I understand Mark correctly, the issue is not whether it curves or bends; the issue is whether the curve or bend happens to create a compound slope that is too steep.Let me take a stab at the implications of this - - you would need to evaluate 2-3 things:
1. Check the slope at the tightest / shortest possible route (the inner radius or bend)
2. Check that the cross slope does not exceed 2%, or that any combination of forward + cross slopes exceed 8.33%.
Also, implied by the words "end of run": Check to make sure the curve or bend still allows a 4' wide path without requiring pivoting or sharply turning on the inside wheel or loss of momentum on one side of the chair (otherwise it might be considered an "end of the run" for that wheel or side).
Did I miss anything?
