ResContractor
Hi.
I am buying a small commercial property. It's a retail building that measures 128' by 40', and it has 4 different tenants. The building was originally separated in six stores/spaces, but right now one of the tenants is using three of the spaces as a coffee shop.
Now, if you go up in the attic space, you can see the attic completely open from side to side of the building and from front to back. So basically when built, there was only the four exterior walls and roof and attic for the entire building. The separation for each store is made by partition walls but not structural walls.
I was told by an property inspector that the building needs to have fire walls in the attic to separate each tenant. Is this something I have to install? even though the spaces can be changed in size and tenants come an go? I was looking online for some information but is not clear.
Thank you in advance for your help.
