We started an annual inspection in an Adult Living Facility today. The building was built in 1998, and I do not know what codes were in effect at that time. The smoke detectors in the individual apartments do not report to the FACP, but the nurses call system. The nurses call system sounds calls the staff pagers. When the nurse call is activated by the resident, a signal is sent to the staff pager, showing the room number. When the smoke trips, the signal sent to the nurse call pager does not show a room number. Staff then goes to the nurse call board, where the room number is displayed, or walks the hall until they see a red indicator light outside the fire apartment. A signal does not get sent to the FACP. Which mean no horn/strobes are activated, neither the FD nor Dispatch is called. When a detector activates, it does turn on an indicator light outside the apartment. When the heat trips the sprinkler, the the water flow does send an alarm to dispatch and the horn/strobes. We hope the resident is still alive at that time. The smokes in the public areas do send a signal to the FACP and the rest of system works as it should. The apartment smoke does make a noise in the apartment andonly the apartement. When the FACP receives an input signal, it does send a signal to the apartment smoke and the smoke does make a noise.
In 1995, my alarm tech wired an ALF. A requirement was that the FACP send a signal to the nurse call. The nurse call shows the room number, but the FACP also trips the strobe/horns, and calls dispatch. Todays job did not send a signal to the FACP that tripped the strobe/horns or called dispatched.
Tomorrow we will call the FM and get his input on this system. I will have my people turn off the FACP breaker and trip an apartment smoke to see if there is battery back-up or not. In there is battery back-up, that will be an indication the FACP supplies power to the apartment smokes. If the smokes do not operate, it will be an indication that the 24 Volt power is supplied by something other than the FACP.
Has anyone seen a system like the one we found today? Any code references?
