Architect1281
I'm told I am the ONLY ONE!
Fabricated turbine structure in 120 MPH Coastal Zone 3 Section to be assembled on-site to 120 feet to generator
so 1704 Special inspect
1704.2 Inspection of fabricators.
Where fabrication of structural load-bearing members and assemblies ....They carry one helluva Load and they are built in the shop..
1704.2.1 Fabrication and implementation procedures.
The special inspector shall verify that the fabricator maintains detailed fabrication yada yada ... relative to the code requirements for the fabricator’s scope of work.
Exception: Special inspections as required by Section 1704.2 shall not be required where the fabricator is approved in accordance with Section 1704.2.2.
SO if they submit a approval from the appropriated acceptable party i will usually let them use the exception....
1704.2.2 Fabricator approval.
Special inspections required by this code are not required where the work is done on the premises of a fabricator registered and approved to perform such work without special inspection. yada yada yadda ...
Why am I the only one requesting Fabricatior Certification of FABRICATED STEEL STRUCTURAL ELEMENTS FOR WIND TURBINES TO BE DELIVERED HERE FROM ........................................
WAIT FOR IT !!!!!!!!
CHINA
Oh we build these all over the place and NOBODY has EVER asked or required
IRONIC GREEN JOBS FOR MERICA YO
CHINA
