Are there any jurisdictions out there that have modified the IBC to require that the special inspector be hired by the owner, thus not requiring or allowing the design professional of responsible charge to employ the special inspector?
Why does it matter if it is the owner or DP. What you do not want is the contractor highering the special inspectors. It is their work that is being inspected not the DP's design.Codegeek said:Are there any jurisdictions out there that have modified the IBC to require that the special inspector be hired by the owner, thus not requiring or allowing the design professional of responsible charge to employ the special inspector?
They also necessitate insurance which a typical E&O policy may not cover.Paul Sweet said:I don't see it as a conflict of interest. A lot of the special inspection items are things that an A/E can spot check. The A/E is just as interested as the building official in seeing that the building is constructed properly, and probably has more exposure to liability if it isn't. I think most A/Es leave special inspections to a third party because they can be very time consuming, and some of them require special expertise.
However, any special inspector hired by the owner is no different. They may or may not have insurance, they may or may not be qualified, and more importantly, like the architect or engineer they are being paid by someone with a vested interest in the completion of the building. And even though it is obvious I guess I need to point out that if the contractor hires the special inspector, the money to pay him comes from the owner as well.Codegeek said:You're correct brudgers; it puts liability back on the DP which they may not want and it may not be covered under their E&O.
E & O insurance it is not a concern of the building department. Is the firm/inspector qualified and what does a department require to be certified? that is all that a building department should be concerned with. None of these programs require any insuranceCodegeek said:Agree mtlogcabin, but not all insurance coverage for E&O may cover special inspections.
A couple of points.Mark K said:The problem with the contractor hiring the special inspector is that when this is done contractors tend to hire special inspection firms that are easy and apply pressure to reassign special inspectors who give them are hard time.In addition if hired by the contractor the special inspection costs come out of the contractors profit so there is more pressure to minimize inspections. If the inspectors are hired by the owner and the inspectors fail the inspection there is less pressure on the inspectors. In addition there is often a mechanism for the Contractor to reimbures the Owner for the added inspection costs.
I'm not being cynical, I'm being realistic. The distribution of honest and forthright individuals in engineering is the same as in any other profession.Mark K said:I suggest that you tell your client that if the AHJ is imposing a requirement that is not consistent with the formally adopted regulations and state laws that the agency is exceeding their authority. Brudgers it is easy to be cynical. If I would adopt the same attitude I could point out the existance of corruption by building inspectors and the other problems building departments have such as inadequate plan checks and limited time to do inspections. In my extensive experience in engineering offices interns are rare. Practically all engineering designers are paid and have an engineering degree and the majority are licensed even if they do not sign the drawings. Engineers in training are typically fairly well supervised. The individuals who make site visits and perform inspections on their own are almost without exception licensed. Sure there are pressures to save money but the design engineer is also aware of the problems that can occur if things are not done right. He is also painfully aware that if things go wrong it will cost him money and pain even if he did nothing wrong. Other than we need to be paid for our work what are the conflicts of interest that are of concern?
An engineer could be a wonderful special inspector. If he/she has Certification for the discipline [that's required here].Codegeek said:Many years ago, when I was working as a plans examiner and had my first case of a DP acting as their own special inspector, I questioned it, perceiving it as a conflict of interest. However, after further investigating, I concluded that the DP would be even better than a third party special inspector because they are more intimately familiar with their own design. There are folks that will disagree with this line of thought, which is partly the reason I posed the original question.
