Spiral Stair Egress
Arch22yrs
Yardley PA
In NJ I have a 4 unit apartment building with two units on the second floor, can spiral stairs be used as a second means of egress?
Not sure why CC noted PA, when you called out NJ in the OP, but the wording is the same in both states.
So not for exterior, but you could enclose each of the spirals in each unit down to the first floor and then exit out a door, this would keep each spiral within it's unit, but I am not sure that helps for your needs.
