Brookhaven 58
- Joined
- Jun 30, 2010
- Messages
- 16
I have a walk up attic of non combustible construction that will be used for storage thus requiring a fire sprinkler system. Due to water supply issue and being a dry system the spacing between heads can not exceed 12.2' in order to achieve the required density. Therefore the distance to the eave or soffit can not exceed 6.1'. The question is where does the measurement end at the exterior wall or at the end of the roof sheathing which extends approximately 2' past the exterior wall creating the soffit or overhang. NFPA is presently OOS. It is a sloped roof.
